Discuss How to wire motor plug in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Im really really surprised and very pleased with all the time and help you have all given me. I really appreciate all your replies.
This may be a stupid question, but if we assume the cable could be wired to an American 4 Pin plug, could it be wired the same way on a UK plug but ignoring the green (ground)??
@Megawatt @Spoon @westward10 @James the Spark1976 @Strima
Yes the 4th wire as y’all know is just an equipment ground the 3 prong is the same as my stove. It’s 220vac single phase and the neutral is mainly for the clock and timer. I’m trying to research it for gingsing
May also be worth it to try and find out what frequency this has been manufactured for. 50Hz, 60Hz or both?
It also could be 220vac with no neutral the 3rd wire being the ground
My experience with 50hz really has no effect with the exception of clocks and timers
I was thinking more the affect on the motor.
It may not be an issue, just run faster or slower..
Hi everyone
I purchased a bench polisher which looks to have come from China. It says its 220v single phase and should work fine in the UK. The power cable has 4 wires in it so I'm confused how to wire a standard UK plug. I have attached a photo of the cable.
Any advice would be much appreciated.
Jinsingh do you have a brand name and model number
Hi Megawatt
I only have the image and details from the advert. It was purchased via Aliexpress which is a Chinese wholesale website.
Where did you get the pic of the 4 wires? (Your original pic). That doesn't look like it's from an advert.
No, we don't use that type of power in the UK, it's specifically N. American. I think the references to US power configs here are misleading, there's no reason to think your machine is wired that way. The Chinese 3-phase colours are red/yellow/green which matches your cable (although I think neutral is more often blue now). I suspect one of two things:
a) they sent you a 3-phase machine instead of the single-phase one you ordered.
b) they converted it to single-phase but left the 3-phase mains cable attached.
Either way, they shouldn't sell equipment in the UK with that cable.
We need to see:
1) Motor rating plate
2) Inside motor terminal box
3) Where the cable terminates inside.
Hi everyone
I am really grateful for all your time and help. Please find attached photos of the motor, wiring, and back of the machine.
Hope it make sense to you guys.
Reply to How to wire motor plug in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, I have purchased a piece of equipment from China and we are required to finish the final wiring. They have supplied a length of 3 core 6m...
