Discuss How to wire motor plug in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
OK, the motor is definitely single phase, but they have left the original 3-phase cable with chinese colours attached. You will need to inspect where the cable terminates, and possibly make some continuity measurements with a multimeter, to find out which colours they have used for line, neutral and earth as it's now impossible to assume anything. In fact it would make more sense to replace the cable to the input terminals as the existing one is totally unrecognised in the UK.
In truth, now would be a good time to call an expert to look at it. Or even call the supplier, although I am not sure whether you will get an intelligible answer that way! However, if you're up for more investigation, do you have a multimeter and are you familiar with using it to take resistance measurements?
Doesn't make much difference MW, we can see the line and neutral going into the motor, but we don't know for certain which cores of the input cable those line and neutral correspond to, as there's a switch and possibly a junction box in the middle. We can't trust that the colours going in are the same as the ones coming out to the motor as it has been altered.
Just trying to help since he came to us for help I understand what you are saying but it drives me crazy not being able to get his motor running. I’ve been on YouTube researching but you are right we can’t just assume anything
Hi
No wiring diagram anywhere at all I will second check to see if any numbers on wires. I will also open the base and see if I can check how the power wire joints the cable running to the motor
It looks from the picture that it is configured for single phase.
Presuming it’s 230v or there about, I would expect this to be a half hour job for anyone who is competent and has a good understanding of ac motors and there configuration for single phase use.
Where in Birmingham are you?
I might be passing you on Monday or Tuesday as I am working that area early week,
Hi
I am just north of Birmingham near West Bromwich
Hi Guys
I've managed to take photos of how the cable from the motor connects to the power cable.
It looks like the black wire is connected directly between both cables, green wire isnt used, Red and yellow wire is connected via switch.
They are useful pics. You are going to need professional help with this because the unit appears not to be earthed unless the blacks are earth, where do the blacks go. The greens appear to have been at some time connected to the switch.
Looks like the black wire is connected between cables but isnt connected at the motor see image
Reply to How to wire motor plug in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, I have purchased a piece of equipment from China and we are required to finish the final wiring. They have supplied a length of 3 core 6m...
