Discuss I am designing a wall light with 3 core 0.75mm cable leads. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am designing a wall light . Can the cable leads from the fitting be connected to the mains wiring inside the wall cavity or does the connection have to be within a terminal housing as part of the fitting?
Not all walls have a cavity, even if it does, any cable joint needs to be within an enclosure.
the simplest way to achieve this is normally to enclose the terminals within the fitting.
Make the base / bracket for the wall lights big enough to accept 2 x 1.5 twin and earth cables as this is what most Uk sparks seem to use these days
Reply to I am designing a wall light with 3 core 0.75mm cable leads. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
