Discuss I need a professional opinion on a recent rewire please in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure what half the pics are trying to show but to me it looks OK from a safety point of view but it's just rough as a badger's.
They grommeted the metal back box and have sleeved the earths, so that's something. It's just that there are some fittings without sheathing going into the box like they should and the second fixing on the wires is shoddy, far too much copper showing.
Don't think this is necessarily inherently dangerous since i've seen a million properties like this but it's just rough. I wouldn't be concerned about your house burning down or anything though.
EDIT: Missed metal not being earthed. That needs to be sorted - if the right fault appears someone could get a belt off that.
Make sure they put RCD protection in at the board.
Thanks very much for your reply
Do you have the EIC for the installation work or has the installer not done the testing and certification yet
In what part of Liverpool are you based
Looking at the consumer unit, personally I would have put the upstairs sockets and upstairs lights on different rcds. (Same with ground floor)
That way, if an RCD trips, your not left without any lights in one room… between ceiling lights and plug in lamps.
unless your bedrooms are on the ground floor and living room upstairs
Was there any mention by the electricians of an SPD?
as been mentioned before, lack of earthing to metal accessories, lack of brown sleaving on switched live wires.
bare copper showing at the terminals of accessories.
Lack of attention to detail on such simple things makes me worry about the general standard of workmanship.
and as @westward10 has already mentioned, anyone doing that sort of work for me would find it was the last job they did for me.
If you have any sort payment due to the contractor that did it, i would recommend not paying it until you are happy at the quality of the work.
also, if there is any paperwork such as an installation certificate, post it up for comment (remove any personal details of yourself and the contractor.
shyte is shyte. can't get worse, shyte is shyte. (caveat. even so may not be dangerous shyte, just ruff).
I think you proding around in there has made things a lot worse if you’re that concerned get a eicr instead of messing yourself no questions it dosnt look great but you have definitely made things worse
Can’t see how it’s been made worse.
I can’t see anything immediately dangerous. It’s rough, poor workmanship, id be ashamed to call it my work, but it’s not immediately dangerous as far as I can see.
metal dimmers not earthed could be classed as potentially dangerous.
non registered sparkies can work for registered sparkies if they are prepared to take responsibility for there workmanship.
It’s immaterial whether it was cheapest or most expensive. A certain level of workmanship should be expected regardless of price.
ive known cheap to be fantastic and expensive be carp.
Yeah but if they are much cheaper then its going to be dog rough and use a cheap contactum consumer unit with no spd.. For those of us doing a decent job at a fair price we lose work to these cowboys and then customers wonder why the job is done so badly...
In one photo the cpc are connected another they are not and in one photo neutrals are inside back box and another they are in the wall
I think the sparky had been back to sort some of the issues between the photos being taken.
If the action of moving a switch plate a few inches from the wall causes problems then I would say it confirms that there is a problem with the workmanship.
Comical really
Coming back to connect a CPC to a metal faceplate is remedying a dangerous situation not fixing an issue
Like you say , you should be able to pull a switch or socket out from a wall without creating a hazard
Reply to I need a professional opinion on a recent rewire please in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have an unusual issue with a recent rewire I have just completed which I hope you guys can assist with. For background, this is a...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
My wife has a electric heated airer, our dog chewed through the cable and I thought it would be no different from rewiring a plug. It's not. I...
Hi all, I've recently had an oven installed by AO and afterwards I noticed in the installation instructions that the electrical connection needed...
