Discuss I need help with wiring this switch in the UK Electrical Forum area at ElectriciansForums.net
Hi guys I was wondering if someone could help me, I’ve got to wire a extra switch in from a grid switch which has an emergency side and normal, I know I’ve got to take 3 browns over 2 being strippers and an earth, I was just wondering if someone could tell me the connections.
The switch on the right, looking from behind, is currently a 1W light switch, and you want to make that 2W with another 2W switch added elsewhere.
Have I got that correct?
In that case it's a one way switch, and would need replacing by the 2 way equivalent.
Once that's done, the wires that are currently in COM(mon) move to L2, and you connect your 2nd switch in parallel - COM to COM, L1 to L1, and L2 to L2.
Reply to I need help with wiring this switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi all, I’ve purchased a Ring Spotlight camera and decided to remove the old spotlight that’s currently installed on the house we recently...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
