- Reaction score
- 4,658
The participants couldn't resist posting.Crikey is this thread still current?
Discuss I never install ring circuits, the potential for danger is unacceptable in the UK Electrical Forum area at ElectriciansForums.net
Have to be a complete Plank to put the lives on a RFC on 2 differing phases, don't you bother to do any testing then, or is it a case of install, connect and hope for the best?I work mostly in coach building/mobile hospitality building, We very rarely use ring finals for sockets for the following reasons:
layouts are always being messed with, so easier to change not having to keep in a ring.
If a cable gets damaged in transit, we only loose a small circuit covering a couple of sockets, rather than a ring which would cover a much bigger area.
some installs are for europeans, and a ring would confuse them!
If something starts tripping while in use, and a muppet starts playing with the DB, no chance of him putting the 2 legs on a different phase!!
The only times a ring has really been used is when there will be heavy usage and only room for a small DB.
I now just prefer multiple radials for other work mainly for their simplicity.
Think I have become radialised.after reading this, think i'll have toringradial my psychiatrist
Also known as spider wiring it is usually using junction boxes and different main points and taking a leg off then to a socket so you'll only ever have 1 cable at a socket rather than 2 but adds a lot of pointless jointsWhat is a tree circuit? ??
….where lights involved, watch your head for dead roses dropping in late autumn......What is a tree circuit? ??
Ring supplying almost whole house (bad & old design) had broken possibly for a while. Socket nearest db on longer leg had a hairdryer plugged in and melted cable insulation leading to a dead short.
Reply to I never install ring circuits, the potential for danger is unacceptable in the UK Electrical Forum area at ElectriciansForums.net
