Discuss Immersion heater tripping mcb when timer switches off in the UK Electrical Forum area at ElectriciansForums.net
Hi. I’m new to this but was woundering if anyone has had this problem. My immersion heater keep tripping the mcb when the timer switches it off. The mcb won’t reset unless the timer is set to on which works fine but as soon as the timer is up it trips the mcb again. The timer I have is a Horstmann Economy 7 quartz. Thanks for ur help
Hi Paddy and Welcome to the Forum.
Sorry to hear you've got an electrical problem, but hopefully someone will be able to help :)
Can you have a close look at the switch that trips and report back what it is? e.g. it may have B16 written on it? Or is it the RCD (one with a test button) that trips?
Paddy are you an electrician? If so I'd connect it straight through and take the timer out of the equation and turn it on and off via the local spur and see if it trips. If you aren't qualified then get someone who is to have a look and they may do the same mate.
If it is not possible to reset the RCD at all with the timer in the off position, then this sounds like a fault with the timer (or a relay it controls). Perhaps the NC contact is connected earth or similar.
Reply to Immersion heater tripping mcb when timer switches off in the UK Electrical Forum area at ElectriciansForums.net
I’m going to call an electrician out on Monday, but curious if anyone has any ideas about this fault: I have a new kitchen fitted and two...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
