baldelectrician
Mentor
Hi All
I have an Indesit drier and it has a fault
It is a IDCE8540BH(uk)
It has come up with a F04 code
I have taken the back off and checked the stats
Both cut out thermostats have continuity, there is a thermistor - this is where I need help
What should be the reading across the thermistor?
Is there a reset possible - I really need an engineer manual
Ta for the help in advance
Depending on the type of thermistor, the resistance will rise or fall if you apply heat with a hair dryer.
Look at the value and measure it. It should be around that at ambient for a NTC type.
A PTC type should be low and rise when heated.
Hi All
Hello baldelectrician,
If You would like to join the UK White Goods Forum I think that you will find that the Members are almost all `White Goods Repair Engineers`.
Here is a Link:
UK Whitegoods • Domestic Appliance Forum - http://www.ukwhitegoods.co.uk/forumsphpbb3/
You should be able to get advice on almost any type of Domestic `White Goods` Appliance on there.
If You do ask your questions on there please let us know how you get on.
Regards,
Chris
baldelectrician
Mentor
Ayrshire, Scotland
Website
https://www.baldelectrician.com
United Kingdom
Business Name
abc Electrical
Indesit drier fault F04- help required
Electrical Appliances & Whitegoods Forum
baldelectrician,
chris murphy,
