Discuss inspection bend cover in outside plastic conduit - top or bottom? in the UK Electrical Forum area at ElectriciansForums.net
I think these were used as the boxes stick out much further on horizontal bends round the edge of a wall. Would these be fitted with the plate on top or underneath?
Ah, okay I get it now, I wouldn,t have a box of anykind there, I would have a bend around the wall from a spring and if the run was long a through box after the bend.
I agree with MDJ - use a bending spring & through box close by...
But if you have to absolutely use an inspection bend around the external corner of a building then personally I'd have the cover on the bottom
Reply to inspection bend cover in outside plastic conduit - top or bottom? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hello, Im really new to the world of conduit. I have some 25mm pvc conduit and cant for the life of me seem to fit back boxes with 25mm...
5K
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
