Discuss installation of a hot tub in the UK Electrical Forum area at ElectriciansForums.net
M
martin bromell
Hi,
I am installing a hot tub in a friends garden,I am using 2.5swa cable straight out of the dis board on a 32A mcb,to a commando switch/socket,I am not sure if i have to use an rcd aswell next to the socket??
If you don't know the answer to this question, I assume you've not read or even got the BGB or the OSG.
So should you even be contemplating this??
You state your an Electrician ... i very much doubt you are in any way competent to do this job ... sorry to be harsh but straight away you have a OCPD higher rated than your CCC of your cable.... id put a bullet proof vest on for the comments coming your way and ring McDonalds and tell them your good at flipping burgers!
PS welcome to the forum :)
Seriously this is a question to embarrass a 1st yr apprentice!
You state 16th 17th edition this would indicate yrs of experience through both editions of the reg's ..im lost for words seriously :nonod:
Reply to installation of a hot tub in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hi Guys So I've never installed a hot tub supply before so take it easy on me. I've spent a bit of time researching it myself and its a minefield...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
