Discuss Installing a dual fuel range cooker in the Industrial Electricians' Talk area at ElectriciansForums.net
N
nickoholism
I am looking for some advise, please excuse my ignorance.
Basically I have extended my property and have a new kitchen which my electician has wired, however there is no 32amp fuse/wire/socket for my cooker.
I have a 1000mm dual-fuel range cooker (gas hob, multiple electic ovens and grill).
Having raised a concern that there should be a 32 amp supply my electrician is adamant that this is not necesaary and that a 16amp supply is 100% fine. He tried to blind me with science about an oven having a 2.5kW element plus ignition being <1kW, add to this a fan and teh ampage needed is <16 etc. Haven't told him I have a science degree!
Anyway, having had my concerns dismissed I have looked on the website of Belling, RangeMaster and Leisure and all of the dual-fuel range cookers appear to have a minimum 32amp fuse stipulated.
Am I being made a fool of?
Will I run into difficulties using my range cooker if I want to use two ovens at once (eg christmas day etc)?
Help!!
Hi
What do the instructions say?
They should state a wattage for all your ovens etc and probably a total kw output.
This will be needed initially to help establish what is required.
personally I would always run a dedicated circuit for cooker, especially a range with multiple ovens!
No way a 16a, I have had this discussion with my electrical tutor. Should use a 32a. regardles if the 16a will hold when your cooker is in full use IT AINT THE REGS! what size conductor has this "Sparky" installed? is he simply classing this as a radial circuit using 2.5mm?
As DYCHE4230 says... whats the total KW output? it will say in your cooker manual.
What max loading is stated in the instructions/installation guide? Do you have an isolating switch, and does it have a plug socket on it?
It sounds to me like your spark (loose term) is fobbing you off.....
randyrat
Reply to Installing a dual fuel range cooker in the Industrial Electricians' Talk area at ElectriciansForums.net
Here is my situation We have a dedicated oven circuit in our house with a 40A RCBO We have bought a dual fuel range cooker which states it has a...
A client has a Kenwood CK405 dual fuel range cooker, for which the smaller of the 2 ovens doesn't work. The elements tested out fine, but live...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
Hi, I've searched these forums and have found quite a bit of good information, but not specifically to my query. My house is about 9 years old...
Hi, We have an old cooker on the mains with a cooker mains red switch with a normal plug next to it. The red switch is in the off position as...
4K
