Sorry if this is in the wrong forum category but I am looking for help with changing light switch facings. I have completed all the plugs which were easy and stumped on these haha.
Thanks in advance.
first u can take that trailing earth out of that connector block but leave all the other earths connected - you dont need to make any earth connections with a plastic switch and backbox.
I don't suppose by some random chance you took a pic of the old switch connections.
It is not possible from a distance to advise what conductors go to which terminal and seeing you have limited electrical knowledge or test equipment the best advice is to get help from an onsite electrician.
As Westward says, you can't determine what conductor does what from your pictures. There are few possible configurations on how this can be connected all dependent on what each switch is doing.
Get an electrician in to sort it for you, it should be relatively straight forward and not expensive.
No more advice on how the OP can trace these connections he has limited electrical knowledge. I will leave this open to see if he responds to @littlespark and his location request.
ACFRAMPTON,
TheReturnOfHightower,
