Discuss IP rating of Nylon cable gland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Amaccc
Hi guys
New to this forum and thought I’d ask the powers to be on here for some advice.
Basically I’m on a job installing some electrical instruments. The instruments are quite small and have come with the gland body , lock nut and ip washer on the outside . The reason for this is to reduce the entry thread for obstructing the terminations inside the device as it is very small. My question is, does this effect the Ip rating having the lock nut hard up against the main gland body on the outside ?
If you are trying for IP 67 or 68 then it’s unlikley to seal well enough because water can creep down the thread.
You would be better to cut the thread length down on the fitting and use a flat sealing washer.
Hi Guys .
Thanks all for your reply’s . Decided to remove the lock nut.A few reworks required on a couple that’s been terminated already but the best solution going forward.
Thanks again
Reply to IP rating of Nylon cable gland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
