P
Plonker 3
Me personally, carry out IR on any cable I have installed, then R1+R2 or R2 and Zs on whole circuit on all legs I have installed.
you verefy by visual and appropriate test/s that the circuit you are replacing an accessory on is good for continued service...I'm not, that's my point, I wouldn't IR test and I strike through the IR test results (while trying to ignore the heading above that says "Essential Tests", implying none are optional). I Zs, I generally do a final earth continuity test once it's fitted (just to preclude CPC having popped out of block or whatever) [=extra 2mins], I RCD test [=extra 2mins]if it's RCD protected and the customer doesn't mind the affected circuits going down.
Opotion 4 = don't bother filling in a sheet at all lol
What would you do if there was a little more to the job? For example if you've added a light to existing circuit.. just a simple one, say an extra light up in the loft. Would you then do all the required IR tests for the MWC?
Or option 6 is that a flapping leaf blowing on the terminals prevented any testing. I miss JRC:rofl:
Especially in the middle of winter, that just cracked me up!![]()
Who is this Flapping Leaf? Have we got a Cherokee electrician on here?
That makes sense Mr DS.. What would you do if there was a little more to the job? For example if you've added a light to existing circuit.. just a simple one, say an extra light up in the loft. Would you then do all the required IR tests for the MWC? The job has taken perhaps 15 minutes, but you now have to take out all light bulbs in the whole house (all on one circuit) and hope that nothing else is on the lighting circuit that you have to hunt down..
My point being is do you ALWAYS do a L-N IR test when doing small jobs (not like for like) and if not what would you put on the MWC?
I then do and record the required IR test for the MWC, which is the addition in the loft, with the CPC connected but before connected L&N, testing only the new wiring, ignoring the existing wiring.
probably what the customer got as well from him...Long story mate
whatwith all the inning & outing, back n forth etc from that one...lol.....
flailing helplessy....a bit like leaves in the wind....
- - - Updated - - -
and the bit about turning up without the test gear.....lolffs...
i said leaves in the wind not tears in the rain....Ha ha and if i remember correctly there was a grand up for grabs for anyone of us that could find this fault pmsl.
And he always referred to the " boys " like he was running an empire of 5wws. ha ha
Just trying to work out whether or not it would be wise to post honestly what I would actually do in this situation on a public forum![]()
