Discuss Is a Fan isolator required in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys you've likely had this asked a lot on here. I have been asked to fit a extract fan wi timer in a bathroom for a friend, i have told him he should get a fan isolator but is adamant he does not want one for some reason (for all it would cost). Is it still ok and safe for it to come on with the light?
The fan should have a triple pole isolator as it’s a timer fan to be able to isolate for mechanical maintenance (taking off the cover and cleaning it) it would also contravene building regs here in Scotland so my gut instinct would be talk him into it or walk away...
Does approved document f apply in scotland?
Down here it covers the airflow rates required when fitting to an existing building then you must not leave it any worse than it was before hand.
So we follow BS 7671 in existing properties for maintenance ...... Part F isn't relevant
BS 7671 says nothing on the subject if my memory serves me correctly..
A MCB or fuse will act as isolation too. The only reason local isolation maybe required would be so the light stays on while carrying out any maintenace on it.
think that requirement came out when we had candles fitted to out hard hats rather than head torches. :(
Nice to have an isolator though, especially if the fan fails and it is winter. If you turn the circuit off without one and the torch has no batteries it is a hard job to change one lol
Most people have mobile phones with torches ..................
No ones arguing, just stating different points and how it can be resolved in different ways. Theres no hard and fast rule for a local isolator, so much like BS7671 its open to interpretation.
Why do some forum members argue so fiercely against common sense when something isn't strictly required by BS7671, bear in mind this is the minimum standard that we have to conform with.
The question asked was "is one required ?"
The question is only being answered truthfully and accurately. If it's a question of requirements then the minimum standards are relevant.
If the question was "is it best to have one ?" then answers might have been different.
Reply to Is a Fan isolator required in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi to all, If extractor fan in bathroom is autonomous does it still require isolator switch or usual fused switch will do? It runs of 12v...
Hi I have bought a new bathroom fan to replace a faulty one. I don't have much cable available (emerging from wall) and it won't stretch to the...
