Surely if you fit an RCBO on each circuit, an RCD is not required?
Of course, a DP Main switch would be to cut all power, but like I ask, is the RCD required as it is incorporated in the RCBO?
The RCD function is included in an RCBO yes. There may be occasions when a different variant of RCD may be required though (100mA / time delayed etc.)
Not required… as long as assuming the RCD is “in series” with the RCBO…
Does happen. And the only issue is, which 30mA device will trip first?
I think your other thread mentions caravans… which is one example.
There will be an RCD or RCBO in the hook up, but also one in the caravan consumer unit itself.
Wigan
United Kingdom
Other
If other, please explain
Van converter / electrical installer
Business Name
Campalot
Is an RCD required with RCBO's protecting the circuits
Rooster,
littlespark,
