I would never alter the design from ideal simply because of cable length. I equally have had problems with through crimps on solids, end up giving them a huge tug to feel confident. I have no issue using a connector block, where, appropriate, once you have a look at the neutral bar, earth bar and all the connections on the breakers there really is no difference between a connector block and these other connections inside the CU. Its a maintenance joint just like all the other ones in there that should be checked for tightness in the appropriate period between tests.
I think my point has been proved. Pliers to crimp joints.... thats why 8 out of ten boards where i find crimp joints usually either has open ring continuity or excessive Zs values or even no earth at all on circuits caused by poor jointing at the board or point where cables are painfully short. I would like to see how many attempt to use a ratchet crimper inside a small consumer unit or enclosure and actually pull of a sound connection or even bother to verify it once done!
I said they are no good under strain. I do not for a second believe that 80% or even 10% of crimp joints you come across have no continuity/very high resistance. If thats what you are implying.
For what its worth I own and use two sets of 'proper' ratchet crimpers, and yes, I pull them afterwards, and test them, and they are fine, and I've never tried to do it with pliers.
When I see crimpers with jaws like this, it does make me wonder if pliers would do the same job!
Nothing wrong with crimps and heatshrink, best way to extend cables, I have tried the wago's I keep hearing about here as well, I was pretty impressed as well, wouldn't want many of them in an enclosure though, there would be no room for the cables :lol:
I never have problems with crimps either. I use a ratchet tool and give each through crimp a bite on each side and one in the middle.
Can't recall ever finding a failed crimp, unlike the countless failed choc blocks that crop up causing faults.
I was referring to crimp joints carried out using pliers or improper crimping tools. And to be fair i never implied that you couldn't use crimps as long as they were properly carried out. Just i would use them only if there was no other means of terminating the cables.
I always try to avoid crimps for mains cables where possible i instead solder extensions to all the wires and cover with heatshrink sleeving
I much prefer wago blocks over crimps. The problem with splitting circuits is why I always install full RCBO boards now on a board change. £20 per circuit, even less if you get any wholsalers own brand board, wagos look fine in a CU, in fact I am a little bit in love with them
Was this the first board you did? Long did it take to fit and how long to test? Just interested in what stage you are at in your electrical trade?
you guys over think stuff lol
plus not that infro in this question, i,e do it mean the 2 lighting ciruits are on the same rcd
i do not see a prob with putting lights and sockets on same rcd
Hum, I extend cables after the old board is off the wall and the joints are "checked" by the tests conducted next!
Wago's every time for me with the board mounted slightly higher than the original
Board if possible, then I tuck/hide the wago behind the din rail
