Discuss Isolators in a kitchen cupboard? in the UK Electrical Forum area at ElectriciansForums.net
What's your view on putting isolators a inside kitchen cupboards mounted on a surface box? I'd normally have them on show obove worktop but in this case the walls are being clad with composite stone. Is there any reason why this wouldn't comply with regs?
Just make sure they are in a position where they are unlikely to get knocked, I usually fit at the front - top so easy to access and switch without emptying the cupboard and can be seen so less likely to be bashed.
Seen it done loads of times.
I've also seen a dedicated hinged false drawer front which housed all isolators in separate surface boxes.
As Darkwood says, don't tuck them away at the back of a cupboard otherwise you may not be complying with a few regs I can think of.
Reply to Isolators in a kitchen cupboard? in the UK Electrical Forum area at ElectriciansForums.net
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
