G
greeny
You know how your tube of silicon sealer has gone solid just when you most need it!?
Do you think that one could use this problem to make a permanent water tight joint, eg using twisted conductors secured in the usual connectors and placed in a suitable small plastic tubelike container and then fully filled with silicon sealant. Leave it to go solid whilst using it as an insulator.
I do know that resin filled methods already exist.
Get it on dragons den.
I wouldn't bother getting it BSI certified, after all, all this IP stuff is only a guideline ...
On a serious note.....SERIOUSLY, you think that's going to be ok.
You should check out some of Pete's videos, he's got a great one on building your own extention leads.
Why not use the propriety types from your local Wholesaler?
Glad someone agrees. 6mm drain hole at the bottom 5 tubes of silicone makes anything waterproof. :D
My own new rating I-B bodging(that)1
Just an idea for making a waterproof low voltage inline joint
greeny,
D00DY_T00DY,
