- Reaction score
- 0
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought all the equipment new about a year ago and have been using the system in the office to supply uninterrupted power to a few devices. The setup is made up of the following devices:
1) 50 Amp 12 Volt Automatic 7 Stage Smart charger with 4 settings (Switching Power Supply, GEL, AGM and WET)
2) 3000 Watt, Pure Sign Wave 12 Volt to 220-240 Volt, Inverter
3) 2 x 200 Amp/Hour, 12 Volt, Gel Batteries
The charger is connected to grid power witch supplies it with 220 Volt AC. The output cables of the charger is connected to the battery poles. The batteries are connected in parallel with the idea being a supply of 12 Volt at 400 Amp/Hour total. There are a two loads connected to directly to the battery poles that draw approximately 30 Watts 12 Volt DC directly from the batteries. The inverter is connected to the battery poles drawing the 12 Volt DC towards it. All connections on the poles are made directly by using lugs with nothing separating them. Meaning all the connections are touching each on their respective positive and negative poles.
The inverter connects to an internal wiring network supplying certain wall plugs with what we call "Inverter Power". The built in Watt Meter on the Inverter indicates we draw an average on 450 Watts constant power when all the items connected to the inverter power is running. I have double checked this with Plug in Watt meter and also noted the max spike for the startup of the devices was 510 Watts.
According to all the information I gathered on various sites on the internet I worked on the assumption that we never want to exceed a DOD of 50% on the batteries. Taking this into account and doing some highly questionable math I figured we should have at least 5 hours until the batteries will need to be charged again. I got to that number as follows: 400ah / 2 = 200ah. 200ah x 12Volt = 2400Watt/hour. 2400Watt/hour / 450Watts (average constant usage) = 5.33 hours. To account for efficiency startup spikes etc I rounded down to 4 hours that should be guaranteed.
The system worked perfectly for the past year. Since we were permanently using the "Inverter Power" for our devices (Basically a bunch of computers, their monitors and one ink jet printer), we never had issues when the power went off giving us a UPS like experience but with much longer battery life. By using a connected Volt meter we monitored the system to ensure we never got too close to 50% DOD. When the grid power came back on the charger would start up automatically and start charging the batteries while also supplying the inverter. (This is all assuming my understanding was is correct that the 50amps from the charger would supply the loads imposed on the battery by the devices connected directly and the inverter. with any excess going towards charging the battery.)
Recently the setup will only last about an hour whereby the batteries would be at roughly 12.5 Volts (Measured with the loads active) then suddenly fall to something crazy like 11.6 Volts which would trigger the built in safety on the inverter switching it off.
Has anyone got advice on why this could have happened and what we may be doing incorrectly?
