Discuss Kitchen light fixture wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Rory Edwards
Hello,
I'm after some advice about how to wire in a new light fixture in my kitchen please. The attached pictures show the current fixture wired up, and also the new fixture.
Thank you!
Rory
Hi Rory,
straight forward like for like swap. Only difference the protective conductors are to be terminated in the connector block.
I would however be looking at containment of the conductors in the ceiling void using a wage box or a round lighting dry line box depending on the ceilings make up.
Please mark the single black wire going to the brown wires with red or brown tape, as it is the switched live.
Full marks for taking a photo before disconnecting the wiring. Not many people do that.
Cut back the CPC also, to much copper showing for OCD
and don't twist the bloody conductors. i hate that. even worse if 2 or more stuffed into 1 piece of sleeving.
Reply to Kitchen light fixture wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Info: Located in US I have a 48” T8 fixture that I recently added LED’s by removing the ballast and wiring directly. After doing so when hanging...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
