Hi guys been a while I've had alot going on in my life with ill ness and one thing and another. Any way long story short.
I lent out my tester to a so called friend and he failed to say he had broken it! I found tin foil around the fuse and the continuity no longer works.
After a massive argument he offered to pay for repair so off it went to kewtech. To which the response I got was its irreparable.
WTF all they have to do is replace a pcb?
I rang them and was told don't make the bits any more.
So they calibrated the rest and I now use it as a loop, RCD and had a cheap continuity tester purchased as a replacement.
I thought I'd give it a go thinking it would be a component or track blown. Cannot see anything and I do not even know which of the three pcbs inside does the continuity.
we'll scouting the internet for help or schematics is impossible it seems and asking for help is not working.
So I put it to you anyone know anything about repairing these can advise or any way I could get it fixed?
Hope you read to the end without falling asleep, just trying to give as much information as possible.
Cheers mike
Cheers mike
