Discuss kt64 continuity boom!!! in the Electrical Tools and Products area at ElectriciansForums.net
michaelw6
Hi guys been a while I've had alot going on in my life with ill ness and one thing and another. Any way long story short.
I lent out my tester to a so called friend and he failed to say he had broken it! I found tin foil around the fuse and the continuity no longer works.
After a massive argument he offered to pay for repair so off it went to kewtech. To which the response I got was its irreparable.
WTF all they have to do is replace a pcb?
I rang them and was told don't make the bits any more.
So they calibrated the rest and I now use it as a loop, RCD and had a cheap continuity tester purchased as a replacement.
I thought I'd give it a go thinking it would be a component or track blown. Cannot see anything and I do not even know which of the three pcbs inside does the continuity.
we'll scouting the internet for help or schematics is impossible it seems and asking for help is not working.
So I put it to you anyone know anything about repairing these can advise or any way I could get it fixed?
Hope you read to the end without falling asleep, just trying to give as much information as possible.
Cheers mike
I lent my lads core drill this week, and burnt it out. Gonna cost me £150 to get a new one. Meantime I send the broken one away to see if it’s repairable. He’s coming over the weekend to drill the remaining holes with the new core drill.
See where I’m going with this? :)
Cheers mike
Not disagreeing with you, but they're still selling KT64 brand new - how can there be no spare parts?
and if it's not repairable..... get a Megger.
Come on now, it's not just a board, it's the paper work and man hours spent faffing around with a meter. They probably told you it's not repairable because it's cheaper an easier for you just to buy a new one.
I had Bosch laser level, and I cracked the glass lenses, laser still worked okay. Unrepairable according to Bosch, 'cos they don't sell spares.
i had a 1552, ragged readings on continuity range, called back by calibrators as unrepairairable . was just a soldered connection on the back of 1 of the 4mm sockets. took 20 mins to fix.
I got a Megger PAT 150R kept on coming up with a fault code on startup rang Megger told was an internal fault and have to send it to them and pay them to fix it turns out that it only needed new rechargeable batteries.
Telectrix- Thats just what i was thinking!
Barnaby- Ive checked all fuses.
Rob- Its my time im not fussed if i got pointed in the right direction.
Thanks for the company details guys.
The new KT64 are different internals i was told as i did think the same!
Secondhand kt64 as little as £150
Secondhand kt65 as little as £300 now
Im hoping im not having to spend that amount.
Reply to kt64 continuity boom!!! in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Firstly I am new to the forum, so will start by saying hi. I work as an electricians mate, and am joining the forum to gain experience...
Hi there, I'm looking for a bit of friendly advice whilst trying to fix my motorbikes cdi unit. One of the pins corroded and came off and i was...
I've been retired a few years now so no longer active in the industry, but I've been doing electrical "stuff" for most of my life. Trained as a...
I will start by apologising to @westward10 as he will have had to take time out to move this thread to the correct section. I am terrible at...
6K
Hello all, I’m looking for some advice regarding a recently broken MVHR unit in my flat, model Heatrae Sadia Advance. The unit is out of...
