Discuss Lamps blowing cont... in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Evening all,
A while ago I started a thread about 11 halogen lamps blowing fairly often.
Over the course of the last few months the problem seemed to improve after I found 2 junction boxes that were pretty leaky and sealed them. The problem now seems to be as bad as ever with one blowing perhaps every week or two.
They are standard bulkhead light fittings with halogen lamps located on a fence along a long driveway. The lightfitting itself seems well sealed and there was no sign of water ingress or condensation. Underneath each lamp is a junction box which I think may be the (main) problem. After opening a few, there was quite a bit of condensation in each. They all have a 4mm drain hole.
Apart from this problem they are all getting switched on/off a fair bit as they are on 2 sensors and a timer so this will shorten the lifespan, but not to one bulb blowing every week.
They are good quality lamps.
All connections are sound, including the busbar.
The lampholder connection is nice and shiny.
It is not an excessively windy location.
Apart from the amount of times they are getting switched on/off which I guess would be 10% of the problem I believe it will be due to the condensation in the JB's.
My question is would putting a potting compound (magic gel) in each of the JB's be a good idea? If it is the condensation causing the problem, would this alleviate it?
I haven’t read the other thread but halogen lamp quality is poor in general. Their biggest killer is over-voltage, closely followed by fingerprints on the glass. They are also sensitive to vibration. Just a bad lamp for outside lighting in general. Time to bite the bullet and install something better!
I hadn't noticed that it's halogen lamps. Fixed to a fence they are going to be moving around a bit.
Have you considered changing the lamps for something less sensitive to movement? What lamp base are they? If ES/BC them put rough service lamps in an see how it goes.
Exactly what lamps are fitted now? Are they the halogen replacements for GLS lamps with the quartz capsule inside a glass bulb? If so, I can't imagine condensation has any effect as it can't get at the capsule (and the glass is not sensitive to thermal stresses) but I can totally see it being vibration. They are much more fragile than the GLS types they replaced, especially the low wattages on account of their very thin filaments.
I cannot see what objection the owner would have to upgrading to LED, as it can't be cost-effective to be replacing these things constantly. Just watch out for the inrush on the timer / PIRs!
Cheers guys? I have asked them to change 2 of them to LEDS to see what effect that has. If they don't blow over the next few months that may be the solution. There was quite a bit of condensation. I was thinking that at times this may cause a short circuit and blow the lamp.
PS... Yes, they are 'halogen replacements for GLS lamps with the quartz capsule inside a glass bulb' Lucien. Also they are ES fittings.
Reply to Lamps blowing cont... in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Recently had to replace one of the 25w pygmy lamps in my oven, first lamp lasted around 2 weeks before it blew, I just thought its...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hey all, I'm trying to restore some switches in a house that's only nine years old in place of some terrible motion sensors. History is quite...
  • Locked
5K
Not been on here a lot recently, so don’t know if this has been posted. I know this subject has been discussed before, but here is the final...
4K
