- Reaction score
- 5,636
Evening all,
A while ago I started a thread about 11 halogen lamps blowing fairly often.
Over the course of the last few months the problem seemed to improve after I found 2 junction boxes that were pretty leaky and sealed them. The problem now seems to be as bad as ever with one blowing perhaps every week or two.
They are standard bulkhead light fittings with halogen lamps located on a fence along a long driveway. The lightfitting itself seems well sealed and there was no sign of water ingress or condensation. Underneath each lamp is a junction box which I think may be the (main) problem. After opening a few, there was quite a bit of condensation in each. They all have a 4mm drain hole.
Apart from this problem they are all getting switched on/off a fair bit as they are on 2 sensors and a timer so this will shorten the lifespan, but not to one bulb blowing every week.
They are good quality lamps.
All connections are sound, including the busbar.
The lampholder connection is nice and shiny.
It is not an excessively windy location.
Apart from the amount of times they are getting switched on/off which I guess would be 10% of the problem I believe it will be due to the condensation in the JB's.
My question is would putting a potting compound (magic gel) in each of the JB's be a good idea? If it is the condensation causing the problem, would this alleviate it?
