- Reaction score
- 25,606
Eightieth think Pete might choke on that.
Discuss Large Volt Drop in ring circuit in the UK Electrical Forum area at ElectriciansForums.net
Not sure yet, going to have a nose at the real ale in Asda and see what tickles my fancy. Might get a couple of bottles of SA in, who knows
Cheers staticA belated birthday greeting , Pete999
Guys
I know 240 IS LOW VOLTAGE
Once the pat tester highlighted the problem i got out the MULTIMETER
60 volts L-E + L-N
Did you measure N - E ?
It can't be that bad if it highlighted the problem, I just need more time to retest the whole system starting at the connections in the CUAutomated instrumentation ,
(and what it decides to do when it detects Danger)
..about as useful as an ostrich ..
Not all bad , I'm angry with myself for believing in it ,and falling in the same trap again.It can't be that bad if it highlighted the problem,
Mr Random 2 , I thought my phone was bad ,Are you related to Buzz.
Ah I am with you now.Mr Random 2 , I thought my phone was bad ,
(Maybe he uses one of those voice recognition apps . )
No sugar coatings ,
Both feet first ,
so maybe I am --on another planet for sure--
Enjoying life , definitely !
not has bad has that , on any muli tester I would say if you have rightAre you related to Buzz.
.... on any muli tester" it" would say if you have right
voltage like 230 v
test voltage 50vIndicates the preset fault voltage limit. The default setting is 50 V. Some locations require the fault voltage be set to 25 V, as specified by local electrical codes. Press when you turn on the tester to toggle the fault voltage between 25 V and 50 V. The value you set will appear on the display and will be saved when you turn the tester off. Is that when my Spark symbol shows 230+/- 5% (on his Fluke)
Or just anything over " safe" 50V ?
(warning energised)
Im wondering if I have some AI in my DNA ! (humanized random miss spellings)Are you related to Buzz.
Reply to Large Volt Drop in ring circuit in the UK Electrical Forum area at ElectriciansForums.net
