Discuss LED Downlighter problems in the UK Electrical Forum area at ElectriciansForums.net
Is anyone else finding that LED downlighters are failing earlier than the spec? I've been buying Aurora FRL903s because they look good and the spec gives them 75000 hours but over a period of just a few months several of them have failed and the failure frequency seems to be increasing. First they start to flash then one of the LEDs fail altogether. If others are finding the same then I'm wondering whether it could be a design fault. Any ideas or comment from the LED experts?
i've got 16 kosnics in a customers house. 2 have failed within 4 months. not bloody cheap at £12 a pop, either.
I'm using kosnics, used loads of them, but in one house where the bathroom ceiling was lowered and clad in plastic cladding, every single one of them (6) has failed over a period of about 3 months
the replacements have worked perfectly since.
i wonder if it was a dodgy batch or they may have been dropped causing a shorter life
Well least if you buy from wholesaler , you can take back easy enough..... Think 75,000 hours is about 8 years constant running so say at most 10 hours a day taking it over 16 years gurantee. Put in diary i said to one client..
The wholesaler has taken them back but that's not the problem - it means so much hassle, time and effort that is wasted and also confidence in a product that I recommended in the first place. And they are not cheap either.
Cafe I done recently, I gave him 5 spare so didn't have to run back and forward. Obviously he payed for them within quote , think 80 odd all in. None failed yet in 5 months. Smd ones. £7 each
No, they are the normal FRL903 Cool type that aren't dimmable, all installed downstairs in the voids between the ceiling and floors upstairs so there's no insulation to cause overheating that you could get upstairs from an insulated loft. I just can't explain why in several different houses I'm getting similar failures after only a few months use.
we've fitted over 1000 of those aurora's in the last two years and not had one fail ??
are you sure those fittings that you say are failing are not covered up by thermal insulation ??
the main reason LED fittings blow is due to overheating, make sure they are well clear from any insulation.
I don't bother with retro fitting LED GU10's anymore. not worth the hassle IMO.
on the aurora fittings with 7 years guarantee and no chance of the client fitting halogens after you cant go wrong. and at £20 a fitting they are the same or sometimes cheaper than buying a standard GU10 fitting and adding an LED lamp.
re-reading the post...
no insulation... could be a funny batch of fittings ??
Same here install tons of these on a weekly basis, only had one fail so far (around sept/oct last year '12) - great product though :smiley2:
JCC fireguard 7's are my choice. 10 year guarantee not had one give in yet. Look the part too. Also the light is equivalent to 50w as well as the light colour being the same as a GU10
what wattage are they?
I've been installing mainly 4W, GU10 with no returns or overheating issues yet
The terminals on the jcc fittings are rubbish and the fixed driver to the fitting is not ideal IMO
Reply to LED Downlighter problems in the UK Electrical Forum area at ElectriciansForums.net
Had a Knightsbridge VFRIC8WW IP65 downlighter fail recently (started to flash), disappointing as only 18 months or so old and probably only a...
This is just a note about LED bulb failure. We had a desk lamp in which the A19 LED bulb would only go on after flipping the switch several times...
I have several rooms of downlight fittings with non-dimmable 5W GU10 mains AC LED bulbs, making about 150W total. They run off a single 1.5mm twin...
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
Hi. I have a problem I’d like some advice on, please. If you just want to know the question please go directly to section B of the following. If...
