Discuss LED Downlights Cut into joists in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Hello, I replaced some halogen down lights that had been fitted for about 15 years with some GU10s with LED Lamps in them I notices that three of them where cut into the joists a tad and had pipes hard up against them, do you think this is reason to move them or just leave as be, the old halogens had been in for years with no problems?
Thanks Lewis
IMG_20200616_135924.jpgIMG_20200616_135924.jpgIMG_20200616_135924.jpgIMG_20200616_140415.jpgIMG_20200616_135924.jpgIMG_20200616_140415.jpgIMG_20200616_140500.jpgIMG_20200616_140549.jpg
original post deleted,
edit. I misread, I'd be looking at manufacturers instructions if you have replaced the original fittings as well as lamps.
Doesn't actually state distances just away from insulation and joists which it is not, the ceiling has been over boarded I can't understand why they didn't fit them properly originally.
Kinda agree with Radiohead...much less heat now than before. I presume Bill and Ben fitted the originals?
Yes old lights were halogens with plant pots over them.
The thing with fitting these downlights is...measure, measure measure...
put a test probe through the ceiling (long thin spike)...move and adjust...
i had to install 10 in my daughter's bedroom...ended up 2 x 5 like the 5 pattern on a dice...
ok, so there were a few tiny pinholes to put some filler in, but end result was fine. Of course, if you have limited time...but then, why not just take the time and do the job properly?
Because you have 5 EICRs to do the same day!
Precisely! If there's access from above, there's no excuse.
I fitted numerous downlights in my kitchen...bedroom above.
There were fitted wardrobes in the bedroom, so I lifted the flooring in the wardrobes, and could sight down the spaces between the joists...easy job! Brought the supply into the void under the wardrobe floor, sent the cable down the gaps, just good fun, really!
Ferret wifi hadn't been invented then...great bit of kit!
Imo if you are just swapping the lights I would leave where they are
[automerge]1593281466[/automerge]
Oh and put those flower pots back in the Potting shed where They belong...
Bill and Ben may have installed them, but now those flower pots can be used for a Little Weed!
[automerge]1593281965[/automerge]
I commend this to you all...but I am reliably informed that those control wires were latterly changed to 0.75 mutistrand to improve flexibility and to provide a better path for fault current...maybe
View: https://www.youtube.com/watch?v=3kW7h-5lLC4
I personally wouldn't have put replacement downlights in that have removeable lamps. I know you have put in LED's so the amount of heat next to the joist will be negligible, but at some point someone will put a 50w halogen in. I don't usually fit integrated LED downlights, but in this case I would have.
Also, this is assuming that the existing downlights are just right up against the joist and not actually cut into it (its difficult to tell from your pictures). I wouldn't replace them if they had been cut into the joists as I feel I would be taking some responsibility. I would have told the client to get someone in to check it was safe.
Yeah in places they are cut into the joists, I understand where you are coming from as the one I removed to check hole size originally was done properly, and got the lights and lamps etc and just went ahead with it and now as you say I feel responsibility for the job. I told the guy to only use 5W LED lamps but as you say one day you never know....
Hmmm...interesting point there.
But the chances of someone putting a 50W halogen in there at some future date is fairly unlikely...not totally impossible, I agree, but in the overall scheme of things, and bearing in mind the incompatibility of halogen and LED...
Not sure about your point re up against or actually cutting into the joist...either is a hazard with halogen...it's marginal, I know, but to walk away from the job, when there has clearly not been an issue previously...I dunno...
not looking for an argument, my friend, just a discussion...
and following my complete renewal of halogens for LED, if you need about 50 halogen GU10s. let me know!
[automerge]1593283106[/automerge]
You got the right lamps, you gave the right advice...what more can you do?
An email to the client, confirming what you did, why, and what not to do in the future...that's all you can do. keep a record of it...in 20 years time some idiot will fit 50W halogens he bought cheap...not your problem, he will have changed the characteristics of the circuit, not you.
Before some of you jump on my case...you can never guard against the folks who use circuits for a purpose they were not designed for...and you should bear no liability for that.
Reply to LED Downlights Cut into joists in the UK Electrical Forum area at ElectriciansForums.net
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
I'm homeowner and moved into a property which has 25 halogen downlights, I'm hoping to get an electrician to replace these with LED ones, what...
