LED downlights in bedroom flicker momentarily when heat lamps turned on in bathroom. Bathroom has 3 in 1 heat/light/fan with 275W heat lamps. I can try to check if any other downlights do the same if that helps. Is this something of concern? All lights are new installed by a registered electrician when the house was renovated before we purchased it. Even the switchboard was upgrade.
turning on the heatlamps may cause a momentary volt drop which is seen by the downlights, causing them to flicker. if the installation is sound, then it's nothing to worry about.
Auckland
New Zealand
LED Downlights flicker slightly when heat lamps turned on
Lighting Forum
Khadanja,
telectrix,
