C
Carlosfandango
Forgive me if this has been covered previously but what led lamps do people find the best? I've tried simply led ones and have had a few faultys. Currently using loxa ones but I prefer smd's. Have used robus and halers but sometimes the customer won't pay that sort of money!!
Depends on the application for which you are using them.
SMD LEDs give a wide angle of light but the light intensity will be lower, if you are trying to light a room then SMDs are good.
The single or triple LED spots are a good light replacement for standard GU10 /MR16 as they will have similar lighting effects.
Light output over 300lm is starting to get to 50W halogen levels, but you also need to consider the efficiency as a lot of them are not as efficient as you would expect.
Dedicated fittings do tend to be more efficient as they can design the heat sinks into the fitting and you can now get a wider range of light outputs and colours that can suit most applications, however as you say they are a lot more expensive and it is hard enough to convince them to pay more for greater efficiency.
LEDhut is often recommended as having good quality lamps. I have found some problems with lamps from RS.
A lot of retailers are selling very poor quality lamps, though I tend to find that dimmable ones that have more circuitry tend to be more robust (but again more expensive).
led hut and convertabulb do decent smd lamps at sensible prices.
Try prolite 5w dim able straight from the supplier. They give £1-2 off retail. We ordered 190 and got them for £11 instead of £13.
Definitely stay clear of the cheapy ones. I've tried a few different cheap-end ones and the light output is poor, and then it gets even poorer when the lamps go bang and cover themselves in black soot. Not good. Daz
