Depends on the application for which you are using them.
SMD LEDs give a wide angle of light but the light intensity will be lower, if you are trying to light a room then SMDs are good.
The single or triple LED spots are a good light replacement for standard GU10 /MR16 as they will have similar lighting effects.
Light output over 300lm is starting to get to 50W halogen levels, but you also need to consider the efficiency as a lot of them are not as efficient as you would expect.
Dedicated fittings do tend to be more efficient as they can design the heat sinks into the fitting and you can now get a wider range of light outputs and colours that can suit most applications, however as you say they are a lot more expensive and it is hard enough to convince them to pay more for greater efficiency.
LEDhut is often recommended as having good quality lamps. I have found some problems with lamps from RS.
A lot of retailers are selling very poor quality lamps, though I tend to find that dimmable ones that have more circuitry tend to be more robust (but again more expensive).
