P
peehead
A bit of advice needed for a quote I need to give. Customer wants an LED light put on a purpose built outdoor building that is used for an office. Wooden construction about 3-5 inches thick with insulation. I'll be putting it on a mechanical timer switch with supply from near by light switch, about 1 meter t&e.
1) Can anyone suggest a good low powered LED light with driver inside the housing?
2) what or could I do with with the LED driver if it's going to be separate from the housing as I'm not keen on putting it in the wall due to heat transfer and ripping out the insulation?
Many thanks
Many thanks
