Hi,
I've fitted four 3w led spots to my bedroom. My touch sensitive light switches only work with a minimum of 40w load.
Any ideas please?
ps... Don't say add another 10 spots. :)
Dave and editing does state in the post which mod and reason, if it does not, then it hasn`t been edited.
Last post edited on this thread was 36 by Sintra due to language.
Well there's something funny going on here then! I see nothing in that post about it having been edited, could it be due to my using tapatalk to view it? If so it could explain some of the complaints about posts being edited without explanation.
This is what I was talking about yesterday, a quick note at the end of that post in italics to say 'edited due to inappropriate language, moderator1' or whatever the reason was would have helped everyone understand
Thats OK but when mods step in and completely delete posts, which they have in here several times its bang out of order.
Now back to the OP, I'm sure I'm a bit dislectic as I can read his name another way!
It must be Dave because I can see what Tazz said ie, sintra time reason.
....could it be due to my using tapatalk to view it? If so it could explain some of the complaints about posts being edited without explanation.
Yes it's almost certainly a tapatalk issue. Apps for mobile devices often leave numerous elements of the full page style layout unparsed in order to make it more small screen friendly. I'm not a tapatalk user so I can't offer advice apart from maybe scour the app settings and see if there's options that can improve things.
your right marvo it leaves that info out on tapatalk
Which wholesaler quoted you that price?
Instead of asking 'any ideas please' you could ask 'is there a way to make this work without adding extra lights or changing the switch?' Or 'is there a way of satisfying the minimum load requirement without adding more lights'
Hi,
Any ideas please?
ps... Don't say add another 10 spots :)
Hi,
Any ideas please?
I would suggest you read ALL the responses as there are some very constructive ones!
going to say replace all the LEDs with candles or gas lamps. just to see if my post is edited as irrelevant, trolling, or off topic. :hammer:
Led lights / light switch
pritch,
telectrix,
