T
Toplad
Hi
Have little issue
Some Led lights have been wired incorrectly, instead of series the connection, it's connected in parallel. The supplied transformer/driver is 350ma constant and connected in series the lights are pulling 3v each. There are 9 lights in total and are set and can not be accessed.
I was thinking that if install a resistor in series between the driver and the first light this limit the power consumption and stop the led melting, not sure of the correct way to work it out?????
I can only access the cable at the driver end btw, everything else is concealed
Any ideas
Have little issue
Any ideas
