Discuss Led strips now red or green colours in the Lighting Forum area at ElectriciansForums.net
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason red and green just stopped showing and i can only go white, yellows and blues. I turned it off at the mains and when i turned it back on i changed the colours rapidly and the green and red suddenly started working. For a few minutes then stopped again. I dont think its a problem with the strips as there are 2 strips connect to one controller and they're both the same.
How can i fix this?
Try disconnecting one set of led strip, see if the problem goes away.
If the problem remains, swap to the other led strip.
if the problem still remains then it must be the controller or a wiring Error that is common to both sets of led strips.
Thanks james, it was working ok with the same wiring and and i did see it working again briefly then stopped with no change to the wiring, i think i'll need to replace the controller. But i'll try disconnecting one strip first
Reply to Led strips now red or green colours in the Lighting Forum area at ElectriciansForums.net
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Not sure I'm posting in the right place but: We had a pool built. There are 5 LED waterfalls installed. The LED strips can toggle between 5...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Am fitting a new pir led floodlight . The exsisting light is connected to 4 core round flexible cable, core colours green/yellow, blue, brown...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
