Discuss LED up liighters for swimming pool in the UK Electrical Forum area at ElectriciansForums.net
N
NG1965
Bit of a help required, I've been asked to quote on up lighters for an indoor teaching swimming pool Currently its lit by 16 50W GU10 up lighters on a 1000W dimmer, customer wants to upgrade to LED but have more light
The pool has a vaulted ceiling and the lights are currently mounted on exposed trusses lighting up a pine ceiling. Around the pool are a 10 wall lights (not dimmed).
Has anyone come across anything that will offer this (and look reasonable). I've spoken with my wholesaler and gone through the catalogues and looked at light bars and individual spots.
Water to truss height approx 9 feet
Thanks Neil
I would confirm the truss height accurately and measure from the highest point on which people may stand to ensure it is out of zone.
The design of uplighter is very dependent on the decor of the pool and also whether they still want them dimmable.
It might be just as easy to use replacement LED lamps of 8 - 10W depending on how much brighter they want.
Reply to LED up liighters for swimming pool in the UK Electrical Forum area at ElectriciansForums.net
Looking at a job where the customer has an indoor semi-raised swimming pool (large Jacuzzi half buried in the floor) & they want down lighters in...
4K
Hi there. I'm building a house and need some help with the LED lighting design. Lots of experience wiring things, some experience using LEDs (did...
Hi I'm looking for a lighting system which will illuminate a wall which faces onto a dimly lit corridor and has artwork on it. The length of the...
Hi, is IP54 OK for down lights in an indoor swimming pool ceiling or does it have to be 12V? Thanks in anticipation, Rob
5K
M
So, I'm doing a significant garden redesign project and trying to do as much of the work as possible. Part of the project is a summerhouse/shed...
4K
Octopus
O
