C
craig7780
Just phoned Yedl today about meter tails length [like trying to get blood out of a stone] they would not give me a figure. I know as a rule of thumb it is 3m but just doing a install where the closest I can locate the CU so it is accesible is 2.4m away.Once I have run the cable under the flloor the length of the tails is gonna be about 4m.There is no room to fit a switch fuse in the meter box and the room behind the meter box is the bathroom. What do you think?
YEDL insist on a switch fuse if tails are over 3 meters, the last time i came up against a similar problem i used 25mm SWA and didnt fit a switch fuse. You can only do what you can do, and 25mm SWA will take some damaging in a domestic environment.
