Discuss Lighing tripping rcd in the Australia area at ElectriciansForums.net
240sparks
Another problem encountered today was the rcd tripping with a lighting circuit. What's the best way to find the fault - with dimmers & sensor lights on circuit??
Sorry, thought that the whole point of an rcd was to protect socket outlets that may be expected to supply portable equipment outdoors. i.e. your ring circuits
Reply to Lighing tripping rcd in the Australia area at ElectriciansForums.net
Long shot but thought I’d try, have a lighting circuit that trips the RCD as soon as the neutral touches the neutral bar for said RCD. Bypass that...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
My circuit panel has two banks of breakers, each bank protected by an RCD. One of these RCDs has been problematic in that it trips intermitantly...
