Discuss Lighting cable needs extending in the DIY Electrical Advice area at ElectriciansForums.net
Soozypoo
Hi all
my dad was an electrician and did work on my house in the early 2000s , i had plaster wall lights and am now in the process of redecorating and wanted to change them , they are seldom used as have downlights in the ceilings, so it’s mainly decorative lighting .I am confident enough to fix up the new wall lights I have purchased,however the existing cable coming out the wall is not long enough to reach the connector block in the new light fittings probably need around another 5cm length I have tried to gently pull to see if it releases any more cabling but it doesn’t I was told by someone I need to rip the cable out and start again but how am I going to do that as it’s running down a cavity ,plus I have no idea where it goes to ,probably into a ring in the bedroom floorboards somewhere which is now covered with laminate ,so that’s not a possibility,have looked into terminal boxes but they are all too large to fit in the recess of new light , again I’ve been told not to use these anyway as they are a fire risk ,so what options do I have ,I know the wall was previously chased out when they were originally fitted but surely there is a simpler way than having to pull all my flooring out in the bedroom rip up the floorboards ,re chase the wall add in a longer cable and have it replastered just to fit a new wall light lol?
many thanks in advance
Can you not move them up a bit this would give extra length.
I could try but if it has metal conduit over where it was chased I’m gonna have to cut that too ,not sure if crimping connectors would suffice ,won’t be hidden in the wall just in the recess of the light fitting which I swear has been made in such an impossible way to get the wires in the block 😂😂 always remember my dad saying this about people providing their own lighting was often the most awkward designs ever lol16378421-48F6-42E4-8206-8306439C95EA.jpeg
Bit of confusion as you stated cavity not a solid wall. An electrician would be able to raise them or extend it without too much grief, bit odd the cable has two red conductors.
Could it be because one is switched line ? I have a double switch next to my front door which controls what was once the hallway and landing ,but I also have a triple dimmer that operates them from the lounge side , we removed wall between hall and lounge , it was 22 years ago so I can’t fully remember back how they were done ,Its A mid terrace ex local authority , I know when he fitted my burglar alarm the mains cable came through cavity as you can feel draught when we took the panel off to decorate 5 yrs ago . I remember the area running above this light cable dipping in slightly as we had to had to refill over it ,sadly as my dad has passed away I can’t ask him how he did it anymore for sure
Reply to Lighting cable needs extending in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
I have Liebherr fridge freezer and need to extend the cable from the appliance to the wall plug. The directions do not allow an extension lead to...
Hi, I am installing a new pendant light. It came as a ceiling fitting with cord and light fitting, and a light shade. The cord needs to be...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi New to this forum, Just looking for some advise as a DIY person. I have recently purchased a new home. I have come across a wall light which...
