Discuss Lights flashing in the Lighting Forum area at ElectriciansForums.net
Zanrek
Hi
I have a bathroom light that requires 2 bulbs. To be honest it was bought a few years ago and I have only just installed it as we've only just finished the upstairs bathroom.
I have the 2 bulbs, (G23 Led 2 pin).
If I don't have both bulbs in, neither bulb works, so I'm guessing the it needs both light bulbs to close the circuit.
When I have both bulbs in they alternate, flashing but one after the other, it's not random flickering or flashing.
Both bulbs have clicked home in their sockets, they don't wiggle or move
If I put a non working bulb in one socket, the other one doesn't flash
Any ideas how I can stop this happening?
TL;DR
Lamp 2 bulbs, bulbs flickering but alternating, not random flickering (G23 9W 2 pin)
Do you have the instructions for the original light?
If it's an older type the ballast etc may be designed for the fluorescent version of G23 bulbs.
Often the LED lamps don't need the ballast but it has to be removed or bypassed for them to work.
I'd try plugging in fluorescent versions of the bulb to see if it then works correctly.
Thank you, I have ordered the fluorescent bulbs to see if that makes a difference.
The light was originally an Ikea light, so I don't remember it coming with instructions other than how to put it up on the wall.
Reply to Lights flashing in the Lighting Forum area at ElectriciansForums.net
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Hi all. I'm new to this forum so thank you for having me. I'm having an issue with my bathroom lights. I have x4 MR11 3.5mm Spots. They've been...
Hello, I am new to this forum and not an electrician. I am an Electrical Engineer though. I have this kind of a ceiling lighting -...
