Discuss Lights flicker when using tools in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Drmadef
Any electric motor, drill etc. plugged into any outlet is (suddenly) making my lights flicker.
Wired my house 5 yrs ago and of course all outlets are on separate circuits w 12g Rolex 20 amp breakers
All lighting is on 14g Romex and 15 amp breakers.
NEVER had an issue. Not the slightest problem.
Then
I plugged in a borrowed tool which had the neutral and hot switched on a repaired plug
Immediately lights flickered and I blew out a plug strip. Nearly caught fire. Wow scared the crappola out of me.
I went to the main box and tightened every hot and neutral connection.
I tested all plugs and all came out normal. Please advise how to troubleshoot the problem. Power is off. No need for panic or scolding I have the power off and I’m going from box to box looking for anomalies. It’s as if a connection was somehow made between my outlets and my lights is that even possible?
can somebody translate this into english for me.. as no offence to the OP but them american terms and references make my eyes go funny... its a bit like metric v imperial..... pints v litres....
I would say that is offensive. Romex is a style of cable used in the States, the rest is in English.
Translation in red;
Any electric motor, drill etc. plugged into any outlet is (suddenly) making my lights flicker. Self explanatory
Socket circuits are 20Amp MCB fed radials using 12 gauge (slightly bigger than 2.5mm sq) flat twin cable.
Lighting is on 15A MCB fed radials using 14 gauge (slightly > 2.5mm sq) flat twin cable.
To date everything has been hunky dunky.
Then
Rogue power tool had reverse polarity wiring in plug.
Large fault occured, sounds like large overload/fault current causing socket damage and badly soiled underwear.
Tightened all terminations in consumer unit in an attempt to remidy the problem
Unspecified tests showed all socket outlets to be full functional.
Looking for further advice, seems somewhat skittish and unsure...hypothesizes the problem may be low insulation / poor separation between socket and lighting circuits.......
The common point for this is the supply source.
( Lamps dimming slightly is quite common -
but once you have noticed a correlation -like old freezers firing up ... your brain has started to tune in )
-- If volts go down out of spec with large laundry
appliances .. would be a clue that supply has got weak.
Thanks for the response. I live in Santa Fe so if you have a reason to go there. Son is a brewer in portland if you’re thirsty.
The drill was repaired correctly but the flickering continues slightly. I’m probably just spooked by the incident but need reassurance. I think I need the main box rewired so if and when an inspector ever looks at it there isn’t any DIY looks to it. During that process any problems should be found.
Got a ballpark estimate for a box require?
easy fix. just swap the lights for coloured disco lights. sorry, colored in USA.
I'd suggest you should get a decent electrician to do some basic tests before you jump into a rewire. If the lights flicker excessively when a large load is started up (motors especially) it would be caused by a drop in voltage but the problem could be an external one on the incoming supply or it could be somewhere in the house.
Reply to Lights flicker when using tools in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
