Discuss Lights flickering on one circuit in the Lighting Forum area at ElectriciansForums.net
D Spanner
Hi everyone. I live in an older home that still has a few circuits with aluminum wiring. One of these is a lights-only circuit that contains 6 switches. All connections appear to be fine. Proper connectors and antioxidant were used for joining aluminum wires and pig-tailing copper to some of the newer switches. Many years, no issues. Recently though, all of the lights on this circuit have begun to flicker. My question is, if the wiring is (hypothetically) bad mid-circuit, can it impact all lights on the circuit, or only the ones after the problem spot? I assume it can impact all lights, but any further input would be appreciated!
From the experience its either the switch itself (or connections on it), or you are missing neutral on those LED's.
I would check switch first since you dont need to climb anywhere and generally its easier to open up
Only the lights downstream of the fault would normally be affected.
Flickering on just one circuit suggests a loose connection somewhere, if all lights on that circuit are flickering it suggests the fault is either at the first light, the panel or between the panel and the first light.
Thanks Dave, this is extremely helpful in narrowing down the likelihood of where the problem is. Greatly appreciate your response!
Reply to Lights flickering on one circuit in the Lighting Forum area at ElectriciansForums.net
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
