Discuss Lights trip rcd when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Hi, ive came across a fault today, the house has been rewired a month back and I was called today because the rcd would trip when the bedroom switch was turned off, it would turn on and work fine but as soon as you switched it off it would trip out, there is a standard pendant and single pole switch, insulation resistance checks out fine so im baffled to why this could be tripping.
have you tried it with no lamp in the fitting?
incase it is something else on the circuit?
Reply to Lights trip rcd when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
