Discuss Long SDS plus drill bits in the Electrical Tools and Products area at ElectriciansForums.net
K
keith915
Just a quickie guys. Looking to buy a threesome of 1000mm or 1200mm masonry bits. Any recommendations? Erbauer/Titan are possibilities but open to spending more on better quality bits.
one word of warning. never attempt to start a hole with one of these. they can suddenly bend at 90degrees and rip your face off. always start hole with say a 16" bit then shove the long one in.
I wanted a 1000mm x 20mm the week before last and was buying it as a single for £ 19
Spotted the same make 3 different sizes in a pack under the display unit for £ 20
bought one of those sets 14.99 and it was cracking , drilled a few holes through stone at a castle with the 20 mm if i needed a larger hole i went through again with the 25 mm it lasted ages , if fact the last time i used the 20 mm i was drilling a 2 ft wall and half the end snapped so a went out and got a new audax 1 meter 20mm £87 + VAT , it drill 12" and burnt out , so i finished the hole with my good old faithfull half tipped drill bit , and got a refund for the expensive one !
Seems a split decision between cheap and expensive!
Struggling to find some Irwin sets but I've found some silverline ones which I'll try out. £13 is the cheapest I've found for the 1000mm, £29 for 1500mm sets so will see how they go.
Not tried their drill bits, but silverlineC, saw blades are not very good at all; far too soft (sourced from toolstation).
Reply to Long SDS plus drill bits in the Electrical Tools and Products area at ElectriciansForums.net
I can't find a previous thread on this topic, so here goes. There is one sort of house-brick that I dread encountering in my area - they are...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Looking to have a bit of an upgrade of my cordless tools. I'll be sticking with Dewalt as some of it is still in good nick. I find it irritating...
I will start my own workshop and therefore trying to know about all the tools i need for an ideal working environment. In my little journey this...
I need to drill holes in the tile wall for some household tasks. Therefore, I want to know exactly what type of drill bit will suit best our...
4K
