Hi can anyone help.
I have installed some LED's in my bathroom and a fan which has a time delay on it. When I turn the LED's off I noticed they still have a Glow to them, so I put my Multi accross one of them and there are 103v present when switched off. If I disconnect the switch wire to the fan the voltage disappears. Can anyone offer any advice as to how I get rid of the voltage feedback from the fan???
So when you turn the fan off at the isolator the glow goes
does it also stop glowing after the fan has stopped running
Have you wired it thro the fan switch ie feed, switch line all going thro fan switch
What make are the LEDs
Yes all through the fan switch correctly, the LED's are Minisun Warm Whites... there are alot of electronics in the fan I'm wondering if it is something in the fan that is causing it... I dont know really.
Disconnect the fan and make cables safe in wagos as a temporary measure and see if it's still happening, Process of elimination.
Phil measure your "phantom voltage" with an analogue meter if you have one, if it disappears when doing this then you need a snubber.
Hey, Yes it does disappear, so please tell me, what is a snubber? Cheers
The subject has been done to death on here, search for terms such as "snubber" and "phantom voltage" etc. on here and this will explain all, there is a search forum box at the top of the page near where you sign in.
Hi S68 :smile5:
We seem to use the terms 'Induced' and 'phantom' interchangably.. Is that correct? One seems to imply that there really is voltage there (i.e 'induced') and the other suggests its not. If it makes the bulbs glow then it must be there? :uhoh2:
