Discuss Main bonding questions in the UK Electrical Forum area at ElectriciansForums.net
I'm just presuming 'earthed metal' to be part of the earthing system. If something needs bonding, it's not.
I don't really know if they meant earthed as in to the Met or Earthed as in Terra Firma, which is why I asked the question.
It's either extraneous or it isn't.
Have you measured it ?
Not extraneous
I'm just trying to understand the shock risk between the pipework that is earthed by the boiler and another piece of exposed metal if it becomes live temporarily
So you've got 1 hand on the pipework and another on say a piece of live exposed metal
If you have one hand on a live piece of metal and another on a pipe that's earthed via the boiler, then you're going to get one of the worst types of shock you can have, one that's across your chest.
Reply to Main bonding questions in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
I'm probably displaying my ignorance here, but fortunately I'm not one of those people who can't stand to be laughed at! I've been thinking a bit...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
