O
oldtimer
I wonder if they are like the Scemies who say they dont lurk on this forum but actually do but the funny thing is they dont pick on any of it
Does anyone else have ones of these? If so, have you mastered the blue-tooth transfer function?
I'm having problems getting my head around it.
I'm using windows XP wih a USB blue-tooth adapter.
Any help would be GREATLY appriciated!
Thanks,
WS
Yep well I was the same I compared the Fluke and Megger and to be honest there was not much between them although a guy I knew banged on about the fluke carry case being the bonus and at the time I just thought he was Fluke blind but a year later and going up 3 flights of stairs with my small toolbox my Megger case and the bag that held on the bits and peices in it the Megger case was banging against my leg all the way up the stairs. I met him and said lets have a look at teh case i then put my 1553 in it and said where do i sign up so went on line and for £28 I had bought one funny thing is if I had known how much hassle ther was with the Megger case ie tucking cables in whilst try to close it I probably would have opted for the Fluke but then again everybody thinks I have one nowI have to agree with you oldtimer. The case looks like something my old B&Q drill came in years ago, but I was more concerned with the product at the time.
Got my 1730 back a couple of days ago!! they aparently updated the firm ware..
case still has one clip missing. that poped off on firstday when I attempted to close it) thought they would have at least cliped a new one on!
Stuck it on our calerbration box.. 0.45 local. 1.29 at +1ohm then 1.37. then 1.45.. I originally sent it to them for random earth loop readings. tested using diffrernt leads, same problem...
Phoned megger gona get a call back monday.. really I need to use my test equipment. Our company has the NIC inspection in a months time, Im suposed to be the QS!! really could do with brushing up espesially as the firmwares changed and it seems a bit diffrent...
oh well lets see what happens monday..
PS funny thing is our company employs 23 people, and have been looking at updating all their test equipment. (Not 23 but at least 10).
May end up looking at fluke, which was my last tester and i liked it a lot... saying that i do like the 1700 series, But its things like the leads, the case and at the moment random readings!!
firstly...the CM200 is an old model....late 90s i think.....it doesn`t do a 2 wire loop....just the traditional method.....the point i was getting at is its quicker than Leigh`s metrel at both low ohms and IR....Glenn, how do you tackle the problem of DIN rail RCD's such as is fitted to the Starbreaker CU's?
I have found the 1730 to be accurate on 3-wire no-trip tests but not on 2-wire. I have tried to get a definitive answer from Megger but to no avail.
Perhaps the Megger support guy on this forum can tell me why it's advertised as a 2-wire no-trip unit but it clearly doesn't give accurate readings.....please.
I'm beginning to wonder if my faith in Megger was justified, and whether I should have gone with a Fluke.
