B
brizospark
My Megger MFT1552 has stopped making the four 'beep' sounds when carrying out a Zs/Ze test, anyone know how to get this setting back to normal as the beeping noise is handy when the meter is slung over shoulder up steps to let you know a reading is being taken!!!!
has the buzzer failed. are the batteries OK. try megger web site for advice from horses mouth
does it beep on other readings?
Hi brizospark
Unfortunately it would appear that the buzzer has failed.
This can be checked by connecting the testleads as if you were to conducting a lead null (shorted at the prods) and switching the MFT to the continuity/buzzer function. The unit can be checked for buzzer on / off by toggling the yellow test button.
If the buzzer has failed then a service will be required.
Kind Regards
Megger TSG
try 07776200146 , oscs, mike does service and repairs.
My megger 1552 keeps saying HOT when trying carry out a low no trip loop or psc test any one have any answers please help
Megger not beeping
brizospark,
mainebankelec,
