Discuss Melting plug socket in the UK Electrical Forum area at ElectriciansForums.net
F
Fletch92
So I hope this is in the right forum area for starters for a first post, sorry if otherwise.
I am new here and do not have any electrician background but needed help from people who do. I live in the North West of England and currently have been having a problem with my plug socket and adapter. I have a four socket adapter with a TV, Xbox, Sky box and router all plugged in but this adapter has melted my single plug socket. The socket now has a huge black hole in the bottom right pin socket and brown residue all over the socket. Is this easily fixed? Do I need the whole socket rewiring? (It is an old socket, in an old house). I am stuck for what to do and thought the forum could give me some insight to my lack of Electrical expertise. Can anyone possibly help me please?
Kind regards
Fletch
well for a start will you please stop using these plug in 3 way adaptors....
i hate the things...
if you must then use a 4 outlet bar extention lead....its fused..
best thing for you here is to get an electrician in to take a peek....
he will be able to give you sound advice on what needs doing and will also be able to guide you on best practice to prevent future problems...
i`m sure theres plenty of members in here around your way that would be able to take a look at it....
These multi way block adaptors are just an accident waiting to happen - change it for a trailing lead adaptor (i.e. one plug into your wall socket with say four outlets). And yes, get the wall socket replaced, if there is no damage to the wiring behind it wont cost much for a spark to call in (maybe someone on the forum if you put up your post code).
Regards.
That Glenspark is fast, doh!
Just call a local spark bud, Sounds like a fault which needs to be sorted. We would just be assuming things advising without seeing some test results
Regards.
sorry...lol...
Chances are it just needs a new faceplate, but get an electrician in to sort it out properly and see if anything else has been damaged behind it. Try avoid overloading sockets with adaptors etc
I got the impression it was a trailing adaptor - I haven't seen any cube type adaptors that have 4 outlets?? Could be wrong though.
Old house, old socket, worn contacts - overheating due to poor contact probably. Daz
Don't forget to have the plugs checked too .... a loose plug wire could have been the initial cause amongst other possibilities no point having the work done if your sparky forgets to check for the cause.
All those items will have moulded pugs on them. My bet is on loose connections on the faceplate. New socket outlet and general check over the system required in order to avoid a fire.
For some reason I wrote this before but it isn't showing as a reply. It is a trailing adapter with four sockets I was using, the only adapter that reaches all four plugs without stretching and tearing them. It is a very old socket, very old wiring I guess. The socket face plate is also rather loose but screwed in enough not to fall off. My house now sounds like a mouse trap right haha? I am currently looking for local electricians in my area, also hopefully I can find an electrician on here but I am still new and don't know where to look as of yet haha. I am going to call one ASAP just to have a check but I was hoping for a brief outlook on the underlying causes at hand. I guess there is a lot then. Again, I wrote this before but I am not sure where it went but thank you very much guys for all your help.
whereabouts are you ? posting your town will maybe get someone on here close to you.
that's not too far for me, if nobody is closer, i can make saturday.
At least you'll get a sensible and trustworthy opinion this way Fletch. Better than risking some chancer (no names, but his 30 mins is nearly up :) Daz
Reply to Melting plug socket in the UK Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
