A
amccormack
I'm a pretty competent DIYer and always try to follow the relevant IEE/IET regs.
Recently I ordered an LED bathroom cabinet from Amazon to replace an existing broken LED cabinet (the mirror was broken). The new cabinet is made out of aluminium, has LED bulbs in the glass on the front and a shaver socket fitted inside.
Before installing it, I checked for earth continuity from the CPC (it uses 3-core 1mm flex) to the metal case on the new mirror and was surprised to find there wasn't one!
This drove my curiosity as to where the CPC was terminated. On removing the top panel, I found an OEM 240v->12v LED driver and mounted directly to the metal case, the 240v+110v isolating transformer for the shaver socket. The incoming 3-core is joined to the LED driver and the transformer by the use of wire nuts, wrapped in masking tape! The CPC just feeds the 12v LED driver.
In my naive mind, the wire nuts and isolating transforming primary windings have a risk of developing a fault, e.g. a wire coming loose, which could lead to the metal case becoming live.
It seems to me the cabinet is a Class I device but it's not portable, so I'm not sure if it counts.
Of course, I could retrospectively fit a CPC, but am I right to be concerned? Should this kind of thing be reported?
- TL;DR
- Online-ordered metal bathroom cabinet with fault risk not earthed.
